- 4 Nov 2002
- England - Leeds
Hi there, please can you offer some assistance, this isnt really a big problem, the PC works fine, but if I ever restart or turn off the PC I have to press F2 everytime and just wondered why.
Basically, my old PC died, and I didnt have any cash so I got a HP desktop/tower from comet, took out the mobo/cpu/ram and put them in a brand new "Cooler Master CM-690 II Lite Dominator Case - Black" which I bought from OCUK = http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=701&catid=7&subcat=29
As you can see the case comes with two huge fans...so I installed the mobo/cpu/ram and put my old gfx and sound cards in aswell as my old PSU...everything went fine and I've been using the PC for past 24 hours.
All the fans on the case are plugged in and turned on, the front one, the back one, the cpu one, everything is fine...but I still get this message, so I found this weird and I took out the fan from the other HP case to see if it made a difference, and it did, the message doesnt appear if I plug in the HP fan, but if I use a coolmaster fan it shows the message.
I tried another fan that is huge too from my old case and it still brought the message up...So I have a total of 4 fans, it will only get rid of the message if I use that one rubbish fan from the HP case...and now you would probably ask me "well, whats the problem, why not just use the HP fan in your case? the more fans the better!!"...well the problem is my new case is amazing and it doesnt have holes for crappy little fans and also the HP fan, the wire coming off of it is like 6 inches which cant reach to the mounted locations of fans anyway in the case because the case is huge...so I cant use the fan even if I wanted to, the wire simply isnt long enough.
So this seems like a really daft situation and yeah this is only a minor problem, not a big problem because I know the case is being cooled and I know everything is fine but I just want to get rid of this message.
So howcome the motherboard will only accept the HP fan as a system fan? Do motherboards know which fans are system fans and which aren't? Does it have some kind of detection? I just thought a fan was a fan? lol Can someone please explain to me why this is happening and how to resolve the situation.
Thanks in advance.
Thanks in advance.
