OK, I'm just trying to make sure my cpu is healthy..
I have an E6700 running at 360x10 at 1.435v. Its never given me any problems with stability, its under water in its own loop with an EK block and a PA120.1 with 1 fan on 5v through a fan controller.
It idles in a pretty hot house at about 30-35 and if I run orthos it loads to about 45 and slowly rises to 50 as the water heats up (unless I whack the fan up) in the task manager it shows 100% of both cores.
However if I run the intel tat load thingy it shows 100% of both cores again but the temps go to mid 50s and rise to about 60?
So what is 100%??
I'm sort of bothered that the temps are highish too but I've done everthing I can to reseat/change the amount of force on the block/reapply as5 etc and I'm no w/c n00b.. plus its knocked nearly 20c off the idle temp and 10 degrees off the load.. and to be fair at 5v the system is basically passive so I probably shouldn't be suprised.
So what is 100%??
