hey folks gilgamesh is back with another EPIC build log!
Remember this?
http://forums.overclockers.co.uk/showthread.php?t=18189366&highlight=gilgamesh
Time to redo the whole case properly utilise the two motherboards in this case, including highly modiftying powdercoat etc
and produce FOUR or FIVE loops!
Anyway here we go
Remember that monstrous MM case on my last triple-loop project? Well here we go again............ I have taken the case to the powder coaters and have had it re-powder coated gun-metal grey inside and out.
Specifications#
Mountain MODS QUAD LOOP yes thats right FOUR LOOPS, how crazy am I?
Specifications
Mountain Mods ascension with the awful mirror black powder coating chemically stripped off and re-powder coated gun-metal grey British Standard Colour Light Graphite. All fans will be blue, ALL barbs will be COMPRESSION this time but CHROME rather than nickel coated. Fan grills chrome coated also.
Specifications:
Motherboard is a MSI X-POWER big BANG X58
Blue black theme
CPU core i7 950
GPU A single GTX 570 OR 580 if
XSPC 580 waterblock
Tubing
XSPC 1/2 ID UV Clear Blue XSPC 1/2" ID BLACK
12 gigs of OCZ FLEX2 ram ddr3 2100mhz now changed to same amount in GEIL ram
OCZ REVO DRIVE 120GIG PCIE SSD
60 GIG OCZ AGILITY TWO SSD
Crucial SATA 3 150 GIG SSD
OCZ Z\ SERIES 1000K PSU for motherboard one now added TWO GEIL THORNBURG PSU's
motherboard two i was hoping for a second msi xpower but msi are YET to get back to me!
TWO lamptron Anti Vandal switches with cables
FOUR X pumps consisting of two LIANG DDC ULTRAS and two SWIFTECH MCP 3550
Which are mounted in two xspc LIANG DDC dual pump bay res
fluid EC6 Clear and TC EC6 Blue
FOUR Radiators to be installed
140.3 front left for CPU
280mm front right FOR planned GPU 3 front right
140.1 for water cooling MOBO chipset at top panel
XSPC RX360MM Fans for cooling TWO 580's gpu 1 and 2
using specialtech's clearance stock of the blue coollink fans at rear panel
A further PSU to be looked at soon
The Acrylic panels have been fabricated from 5MM thick high quality high impact acrylic 901 shade
The artwork is laid out below. Please take a look and note though the design uses blue panels-these are just to help enhance the etching.
Note these specialtech and gilgamesh wording is no longer an outline and is properly filled out.
Note the specialtech logo and even more so the Ancient Sumerian Cuneiform language of which i fluently speak. This language is 5.5k years old and the Sumerian cuneiform reads EXACTLY as thus.
GILGAMESH PASSION FOR HIGH END WATER COOLING.
These 5mm thick 24" high panels cost me 150 notes to manufacture as you can see the lettering is not some cheap vynil or even THINLY laser etched lettering. But these are ENGRAVED on. Then the panels are polished with a Diamond sander/polisher around the edges.
UNLIke laser cut acrylic even when its polished around the edges it leaves tiny ridges. However these are cut with a band-saw andthen POLISHED with a DIAMOND grade sander/polisher to create an ALMOST glass effect. Will update with a photo showing this soon
As you can see I have taken a lot of pride in this project.
Planned colour scheme is based around the specialtech logo. Sooooooooooo
Alphenon fans
To sum up on colour scheme
gun metal grey case
all fittings grills and barbs chrome polished
cpu block chromed
motherboard blue black
tubing blue-black
rads all black
lighting-UV
Bifenix blue black 24 pin EPS connector
2x Bitfenix 8pin EPS blue blACK (AS THIS TAKES 2x 8 pin EPS)
Four water cooling rads for four loops
3x 580 gpus
core i7 p50
pcie ssd OCZ REVO
2 more ssd's 120 gig SATA 3 CRUCIAL
SATA 2 OCZ
GILGAMESH
Remember this?
Anyway here we go
Specifications#
Specifications
Specifications:
Blue black theme
CPU core i7 950
XSPC 580 waterblock
Tubing
Alphenon fans
gun metal grey case
cpu block chromed
tubing blue-black
rads all black
lighting-UV
3x 580 gpus
core i7 p50
pcie ssd OCZ REVO
SATA 2 OCZ
GILGAMESH
