When will we see DIY laptops?
1 Sep 2007
I am pondering over the idea of getting a gaming laptop - but I cant see the point when the graphics card wont last too long and cannot be upgraded.
So I was wondering when we would see laptops that we could customise ourselves?
they do already exist, most modern laptops have panels that you can remove to change various components. If you look in the laptops section of OcUK you'll see they offer their own custom built ones
A competetor did custom shells that you could change the basic internals on and assemble your self a few years ago...
Wasnt all that amazing seeing as pretty much everything is strapped to the board to start with
This is why they dont exist in the format we would all like, the vast majority of laptops have one logic board that everything sits on.
Often even the CPU is physically attached to the mobo in the assembley and isnt removable to replace
One of the main things that holds me back from buying or recommending lappies is the fact that they're hard to upgrade and repair. I'd like to see some truly modular machines come along, but more standards would have to be implemented for it to work, particularly in the gfx.
you can buy mobile cpus, laptop gfx cards and mini pc cards its just that not many places stock them and theyre still expenisve because of this
as said OCUK do custom build laptops
more standards in general would be a start!
Virtaully every range of laptops has its own unique motherboard, cooling, chassis, socket layout etc, theres not really a standard like in desktops (mATX, ATX etc.)
Yeah, this is what i'm getting at. I know you can upgrade gfx etc, but it's too specific to be mainstream I think.
It's hard to imagine a world where dell and the like would let you stick a different brand of gfx or even mobo in the machine. I guess it would also mean a lot of laptops designs would have to fall into certain limits, which would reduce variety and scope in designing new machines.
Screw it, just make them cheaper please!
very very few laptops allow you to change the graphic cards
most have them hard wired to the mainboard
cpu`s can be changed on most laptops
You can buy the shell and internals if you really want to, mainly from trade suppliers but adding up the prices it is usually more than buying a pre-built machine and you've potentially got the additional hassle of trying to calculate the thermal envelope yourself if you want to ensure parts aren't liable to overheat.
I'd suggest it simply isn't worth it for most people and you're still left with the same upgadability problems of a pre-built in most cases.
yeah but only parts made by that manufacturer will fit there case
you cant pick anyones mainboard eg HP/sony/acer etc as there is no standard shape or size like there is with a desktop PC
only universal parts will be DVD drive/CPU/HDD/ram
everything else will be made by the case manufacturer, thats why you cant pick and choose your own parts like soundcard/graphic card/motherboard, like you can on a desktop PC
