OK, it's not a hardcore PC, but it does me for gaming and video editing. I would like to speed it up however, and to do that I need to find out my bottleneck.
I realise that my HDD is the most likely culprit, so what upgrade will you recommend there? So, what would you say is my bottleneck, if you can you could put them in order 1, 2 and 3, and some suggestions for upgrading would be helpful too!
So, here are my specs:
CPU: Phenom x4 9650 @2.3Ghz (possible OC with a new heatsink? Ideas please!)
CPU cooler: Stock
GPU: EVGA 9800GTX
RAM: Mainstream 4Gb @800MHz
Mobo: Biostar TA780GM2+
PSU: Atrix 650w (650w excessive, but it's probably not outputing anywhere near that!)
HDD: This one: http://www.overclockers.co.uk/showproduct.php?prodid=HD-030-HI (25Gb free
OS: Vista HP 32-bit (may upgrade to Win7 64-bit, but I dont want 2 have 2 do a clean install)
CPU cooler: Stock
GPU: EVGA 9800GTX
)OS: Vista HP 32-bit (may upgrade to Win7 64-bit, but I dont want 2 have 2 do a clean install)
, but I wouldn't really like to spend ALL of it. I would say £100 max, but am really looking cheaper for now.
so no real use of it other than backup and archive.
