- 11 Apr 2006
- Earth
Why can I not find a fast mirror to download 3DMark06
Anyone have any ideas ??
monkeypants said:GamersHell is best.
yeah lol i a mdownloading it right now with 800 kbs , thats is realy goodGamersHell is best.
You stole the bandwidth then, its now downloading at an amazing 60k/s off an up to 8mb line -vairo said:yeah lol i a mdownloading it right now with 800 kbs , thats is realy good![]()
oweneades said:Majorgeeks.com is also pretty good ( I assume thats allowable)
Also if you actually try and download the benchmarks directly from futuremark they have a large list of mirrors available.
For example for me on a BT 8mb connection (downloading 3dmark05 and then 03) I got:
Guru3d Europe Mirror - 333kbps
Majorgeeks.com French mirror - 738kbps
Downloaded 3Dmark03 (170odd mb) in 5 minutes.![]()
Liquid_Entity said:I have got the download now, i got getright and then got it from gamershell.
I did try the 3dmark mirror list and 70% of them said they were full and the others were like 20k.
Anyway just done my first test and i really dont know whether its a good result or not ?????
oweneades said:Depends heavily on your setup and what cpu you are running.
If for example you are running 7900GTX in SLI with only a single core cpu your overall score will appear low compared to others who are running a dual core cpu.
Liquid_Entity said:I see, I just posted my score on the 3dmark thread
oweneades said:But you forgot to put down what your system specs are, just edit your post in the 3dmark06 thread with your specs.
Otherwise people won't know whether its good or not.
