Seems to be a minefield of fakes around. Anyone know or recommend a place i can get genuine batteries from? Need an 18650 for a low drain appliance (gamepad).
I have always got ours from either Torchy (battery boy), MultiCorePC or Ecolux (closed until Feb 1st) all on Ebay and have never had any problems with any of them.
I have always used Torchy but his stock has been a bit thin on 18650s. I just got some of the vaping recommended ones from Fogstar, perfect timing for this thread
Do you need protected or unprotected, though?
Most vape batteries are unprotected, as the devices have their own load/draw monitoring & control circuits. Might not be suitable for your gamepad.
Somewhat odd question as I know nothing about this vaping lark. Why are vapers so keep on 18650 batteries when you could use any old rechargeable battery pack I assume? Is it cheaper?
