Where can i get half height i/o plates
Permabanned
19 Nov 2008
Peterborough, England
I'm thinking of mounting my comp in a 2U server case and want to use two of these in crossfire because they are half height but where can i get the backing plates for them along with one for my Creative Sound Blaster Audigy SE 7.1? Thanks aand have a good christmas!!!
Don't forget that its got the cable for the second graphics port. This may mean it was never designed to be used as a half height... Why do you want to use a rack mount server case anyway? The fans they use in those to get adequate airflow are noisy as hell... You've most likely got a reason for it, so i'll say this:
Try contacting the manufacturer to see if they a) supply a half-height backplate, or b) can give you one after you buy it.
