Where can I get power steering fluid?
18 Oct 2002
Anyone know where you can buy power steering fluid from? The closest stuff I can find is something called Slick 50 power steering fluid and it says:
Eliminates and protects against power steering leaks.
Keeps seals in good condition
Stops Leaks.
Is that the right stuff or do I need something else? :confused:
Thanks. :)
