where can i rent a clio?
17 Jan 2006
NW
Im considering swopping my R reg Corsa and buying a new Clio if i can afford it but i would like to test drive one for a few days before hand. Does anyone know any companies i could rent one for a few days? most rental companies ive looked at seem to only do the ford ka or a corsa.
You wouldn't be able to rent at your age anyway would you? Most companies want you to be 25 i think. Why not just go into a Renault garage and ask for a test drive? Won't be a few days but will be a lot cheaper than renting a car!
It would be cheaper to get a test drive from a dealer.
If you look keen to buy and ask for a long test drive the salesman should be able to accomodate you.
mac
Yes I am 21
I proberbly will have a test drive but just dont want them hassling me to buy one afterwards as i prob will. lol.
I would also like to physically just have one for a few days so i can really decide if i want one. Not to bothered if its going to cost me i just want to make sure its the right choice before i buy one.
