That cheaper then what I have found so far ...Well I guess you have already done the normal searches. Cheapest I can find from a reputable seller is £ 2,299.00.
over £2k for a compact?!
Although to be fair it can pretty much be thought of as a fixed lens full frame dslr, or not far off at least.
Still a lot of cash, but a great camera.
Yes what I was going do...Give it a few months after release and it will come down a little (hopefully).
Think of it as a cheap Leica![]()
Well considering the Leica X2 (albeit with an APS-c sensor, 16 megapixels and a 36mm f/2.8) lens is only £1500, then the cheap Leica in this case is actually the Leica
Now if the RX1 settles around the £1600-£1700 mark then it will put a massive dent in the X2 sales.
I was referring to a FF Leica.![]()
