Where do I get Sennheiser ear pads
1 Oct 2005
I have a pair of Sennheiser HD 280 pro headphones and the ear pads have split.
Now according to the instructions I can replace them, so no problem I would have thought, but exactly who stocks them.
Has anyone ever bought a pair of these pads and can you recommend a supplier for them.
I seem to be down to just a couple of suppliers according to Google but one of these has no stock anyway and although
I have left my email address with the company they have not got back so far.
Another wants £14+ for the pads but £8 to post them and £22+ just seems too much.
A recommendation or alternative that would fit would go a long way to helping, thanks in advance.
Thanks for the feedback james but their own spare parts link to a supplier does not do them anymore, so is of no help, and they just say there is a lot of suppliers. Basically as much use as a hole in a space suite.
That’s why I asked if anyone had bought some at a reasonable price and from where.
Thanks anyway
Thanks anyway
As posting links to competitors breeches forum rules, it's difficult for anyone to be too specific as to a source to obtain these items, I suggest you try a popular auction site, or google. With any luck you'll find what you're looking for in a few minutes.
