I recently bough a Gigabyte Aurus Gaming 7 & a i7 8700K. After owning a Z270 Apex I wasn't happy with the board especially as I couldn't run my 8 pack signature Team Group memory at over 3900mhz due to the board not being able to set some of the secondary timings loose enough.
The board is a poor overclocker so I sited being unable to run my memory at it's rated XMP 4133mhz as the reason to RMA as it is advertised as being capable of doing so.
A couple of weeks later the board has been sent back to me with bent pins that 'are not covered under warranty'. The socket cover wasn't on the board and the lugs are bent.
When I called the vendor they said the cover wasn't in place when returned, I know it was as I struggled for 5 minutes fitting it. It looks like some meathead has used too much force to remove the cover he's bent it and probably slipped bending about 10 of the pins near the socket centre.
They maintain that's how it was returned, where do I stand?
I have checked and there is no way I could have bent the centre pins while fitting the cover myself. I have proof I didn't bend while fitting the CPU as I have video footage of me reviewing the board for YouTube with it running.
Any help would be appreciated. I already replaced the board before sending it back with a far, far superior Apex so still have a working rig.
