ahhhh all my fans are already connected by 3 pins.
I've attached the HD audio to the correct part of the motherboard, but there is no sound through headphones. Does anyone know what could be causing this?
1 check you have plugged into the right port on the out put of your motherboard, 2 check it's enabled in windows and bios (windows sees the S/card) 3. it's actually not muted or turned down. 4. check manual for other cables/ connections you need or need to connect
