Where does an Amp sit - and do I need one?
3 Dec 2004
Hello!
I'm really pleased with my sound setup (it is very basic I know but perfect for my needs and to my untrained ear, sounds great).
I use a DAC Magic Plus for the signal convert but also as a handy switcher as I have computers + console attached. Speaker is just a Sonos connected via 3.5mm from the DAC and I know it's nothing special but I think it sounds and works well.
Would it be worth me getting an amp? I was under the impression my DAC would not work without one but presumably the signal is being boosted somehow now (i'm guessing the DAC must have something inside?)
And am I right in saying the amp would sit after the DAC (so the 3.5mm cable inserted into DAC now would go into the amp instead?)
Thank you
One last question, would I need an amp to power a set of headphones do you know (from the DAC magic plus, it has a headphone socket so i'm guessing not)
Got it thanks , I can see the output but was unsure if it needed to go into some kind of signal booster first :) I might order some headphones and give it a go
Depends on the headphones - the headphone output on most consumer electronics will drive run of the mill headphones fine but some higher end headphones will require more voltage or power than basic headphone output can provide which is where a [dedicated] headphone amplifier comes in.
I would think the headphone amp on that would be pretty deceng
Was more a general comment - some stuff has a decent built in headphone amp, other stuff is pretty basic.
The Dacmagic plus apparently can drive stuff up to 600ohm and fairly decent current supply.
