- 5 Apr 2014
Evening all does anybody know where 80-100Hz on a REL sub is please there is no marking on the crossover to know where to set this to. Ruark advise setting the crossover on the Sub to 80-100HZ. I have the 0-120 switch but thats to match the bass with the speakers
The anechoic response of MR1 is flat (+/- 3dB) from 55Hz to 20Khz, although when used in a real room environment with the backs of the speakers sited near to a wall then you will notice a significant lift of the lower frequency with a useful response down to 40Hz. If you require ground shaking bass, then we would recommend adding a suitable active subwoofer which you can run from the subwoofer output on the rear of MR1.
That's the Ruarks response
