- 16 Aug 2011
This is following on from a previous thread where I was having problems installing an OS...
OK, I disconnected the PC from the power cable, disconnected all cables, etc, etc, from the m'board - checked, and double-checked that there was no 'completed circuit' of any kind.
I then took out the CMOS battery using a plastic implement and then pushed the PSU switch to the ON posiiton to make sure that all current was discharged (then pushed the switch back to OFF) - waited at least another minute or more and then replaced the battery. So, I had now cleared the CMOS... I then reconnected all leads, connectors, etc, making sure that all connections were not lose, etc, before replacing the side panel and reconnecting the power lead.
I then booted up and a 'no kboard' message flashed-up for a split second before the speaker bleeped twice, followed by the message 'NTLDR is missing - Press Ctrl+Alt+Del to restart.' This did nothing! So I powered down.
I then realised this was of course because USB was disabled because of the new default BIOS settings, so I connected PS2 adapters to the kboard/mouse and then connected both to the PS2 ports. Powered-up again, and this time it booted OK and there were no display artifacts of any kind (onboard VGA being used).
Then the message 'Enter setup to recover BIOS settings' followed by 'F1 to Run SETUP' and 'F2 to load default values. I selected F1, but again got the message 'NTLDR is missing - Press Ctrl+Alt+Del to restart.' Tried this again, but the system hangs, so I pressed the reset switch and it booted again and I started to press the delete key. BIOS comes up OK and again no display artifacts.
My problem is, that this message ''NTLDR is missing - Press Ctrl+Alt+Del to restart' keeps comming up, and also in the BIOS I can't find anything that tells me what the CPU and RAM voltage is, never mind being able to change it if needed; only overclock voltage figures, but nothing that tells me the basic or 'mean' operating voltage! The boot order is also set to the right order, but I don't really know how to proceed here. Is it the default values I need, or the optimized default values?? What should I be doing now?
but no response to options, and I was also getting 'not enough virtual memory......' flashing up for split-second and then blanking of screen.
chin up
) and also as suggested by Asus, I've already disconnected everything so as to clear the CMOS to set BIOS defaults, then reconnected everything. I selected everything correctly in the BIOS; checked voltages and so on but this didn't help OS install problem...
I'll google it...
