I have 6 case fans my motherboard has:
CPU_FAN - Pulse regulated (PWM)
CPU_OPT - Voltage
SYS_FAN1-4 - Voltage
SYS_FAN5-6 - 3-Pin
By voltage I mean the motherboard varies the voltage going to the fan to change the speed, rather than using pulses. 3-Pins just run at full speed.
My pump needs to go into CPU_FAN because the speed can't be changed on any other header. That leaves me with 5 speed controlled headers, one of which is too far away for the fan cable to reach, which leaves me with two un-used fans.
I'm wondering how people handle this? Especially people with more fans than I do. Ideally I'd like to connect them all to the CPU_OPT header and vary the speed of all of them at once. However, splitters don't work because they only split PWM headers.
Cheers.
EDIT: For example, how has he done it here?
CPU_OPT - Voltage
SYS_FAN5-6 - 3-Pin
Cheers.
