Where to buy pads and discs from?
29 Jul 2004
Esher
Hi everybody,
I need some new brake pads and discs for my Peugeot 307, can anybody give me a few websites that they recommend?
Thanks
Deep
www.buypartsby.com
Interestingly cheaper for EBC "OEM" pads than EBC direct....
Not sure who the manufacturer of the discs they supply are but the regular pads are Mintex items. Ordered a pair of front discs, EBC OEM front pads and Mintex rear pads for £73 delivered.
www.buypartsby.com
Is a "Pad Set" 4 pads? i.e. Front both sides.
This is where I got mine from last weekend, the local branch had the pagid kit at the same price as the website, which so far seem excellent
Do disc prices on the ECP site equal per disc or that's the price for a pair?
I ordered with buypartsby in the end. Their pricing is really competitive.
Discs and pads for all 4 corners, plus a fitting kit for the rears.
Oil, air, fuel and pollen filters.
Front and Rear Bosch wipers.
5l Brake fluid.
Just over £150 delivered!
I know you have already got the lot but for anyone else wondering they are sold per axle. So yes it will be for both front sides.
Thanks for the reply, whenever I have bought pads in the past I've got 4 in a box but wasn't certain if this was always the case.
