Where to connect cable?
11 Oct 2005
I'm installing a NZXT Kraken X61. The instructions say to 'connect the 3-pin power cable from the pump to the 4-pin CPU-PWR connection on the MB'. I can't locate a CPU-PWR connector. I have CPU-Fan, CPU- Opt, and AIO-pump, all of which would fit the plug. Does it matter which I use?
CPU-OPT will give you less grief with the warnings but disable the CPU FAN monitor in BIOS and it's all good.
