- 24 Sep 2007
I have a bit of a back problem so I am looking for a quite specific double bed frame, my requirements being:
- Easy to assemble AND disassemble, so probably a metal frame but doesn't have to be. Must be able to take it apart and transport it easily.
- Very solid, no give in base, no movement in frame, no sag in the middle
- Base should be perfectly flat, preferably continuous base rather than slatted as I don't want the mattress to sag through anywhere
- No sharp edges that I can whack my shins on
- No impediment at the end of the bed, feet must be able to hang off as I'm tall
- Preferably some sort of headboard that is comfortable to sit up against
Does anyone know of a bed frame like this and if so where can I buy it from?
Thanks
Thanks
