Where to find benchmarks for multiple socket systems?
22 Dec 2008
England
I'm trying to get a handle on the relative merits of dual and quad socket computers, such as how four E5-4650's compare to two E5-2697V2's. The former is 32 cores, the latter 24 - but the former comes with double the memory bandwidth and cache coherency overhead.
Essentially I can't judge which way it would go, I don't think intuition is worth a great deal here. Can anyone point me in the direction of finding out how the two systems compare?
I'm trying to work out how much bang-for-buck I can get into a single system for 10k.
Thanks for any suggestions you may have.
It all depends on what you are using it for really but in general terms (most cases) i think the latter would be better.
From my breif research i have found some user comments which mention the improved memory bandwidth and cache as having massive advantages. 30%-40% seemed to be the average improvment in benchmarks. (see this thread: http://forums.servethehome.com/proc...473-ivybridge-xeon-e5-2697v2-experiences.html)
As you can see above, that was comparing a Ivy 8-core to a sandy 8 core, where as you are comparing 6 to 8.. ) though i know you are using different multiples.
I know price may not be a big consideration to you, but the two 2697's (with motherboard and appropiate memory) will be a massive whack cheaper than the 4650's..
That's a really useful link, thank you. It also leads to a discussion about folding @ home which shows an almost linear increase in performance with core count - a remarkable achievement for Intel!
If the code was perfect, we would be memory bandwidth limited. But the code is probably quite a long way off perfect, in which case we're cpu limited.
Budget is a factor but weirdly not the dominant one. I'll need to talk to various people next week about specifications and it's unwise to talk to sales without checking the numbers first.
