where to get a socket 939 retention bracket and plate?
21 Oct 2002
Lincoln
where can I get a socket 939 retention bracket and plate? I seem to have misplaced mine (I never used it and think it got thrown away by accident) and want to build a machine with my board and a retail AMD heatsink. I need the backplate and screws as well.
cheers
parkie
what about ghetto modding one out of plexiglass.first make a cardboard stencil including holes distances and diameter.buy a hacksaw blade and cut out a square of masking tape backed 3mm plexiglass.drill your holes<-practice first on some spare plexiglass.And attatch using small machine screws from b & q.
EDIT ^^this wont work for the brracket though so would be of no use.sorry
I got this from the installation instructions for a Freezer 64 pro:
"Every motherboard should come with a AMD retention module. If there is contrary to expectations no retention module available on your motherboard, ask your dealer since we provide our distributors with them separately."
Hope this helps
T
cheers everyone, I've email asus hopefully they'll come up trumps, I've also got an add in the wanted section, surely someone has a borked 939 board and has one spare!! Do you think it's worth getting in contact with AMD?
p
