Where to get a Twin DHLA Linkage Kit?
18 Oct 2002
Nr Colchester, Essex
I am trying to find a throttle linkage kit for twin DHLA 40s. I have had a part on order for months (not joking) with moss europe and they still are not in stock! The only problem is the linkage cannot stand too high above the carbs as I have very little bonnet clearance.
Anybody got suggestions of a good place to try?
Capt Doufos said:
Thanks, I will investigate. The main problem is I don't think one of those tall ones will remotley clear the bonnet.
The ebay guy sells different versions, I have the weber equivalent of this which is a very low profile linkage. You may also be able to get linkages that fit under the carbs, you definately can for the DCOE's.
Is it good quality? The seller is good I have used him before. I may just go for that.
It's just annoying that I ordered the specific moss part for the car with 15% off!
I don't think it's quite as well made as the genuine Weber linkages, but it does do the job perfectly though. I am thinking he is a bit overpriced however, I orignaly got mine from Rally Design and it was ~£35+vat, and comes with throttle cables and the twin cable adapter for the throttle pedal. Just checked and RD appear to sell the DHLA version for the same price, £35.50 +vat, part number RD4201. However, their rather crappy website has no pictures of the DHLA verson, only the DCOE version.
