Where to get samsung p300 default phone software?
7 Aug 2004
As title, Im interesting in getting one of these from O2 BUT i know about the t9 predictive txt input error on them with the 02 software ONLY, however the 'sim-free' i.e. factory samsung software works fine, where could I get this from? off the net ? my plan would to be pick up the 02 phone then somehow flash it to the samsung default software, i.e. removing 02's stuff
Hey mate, cant help you out with your question but I'm was also thinking of getting one of these handsets on o2.
What is the prob with the predictive text on them?
hi mate, basically you carnt enable t9 input as default, and even if you do it ALWAYS reverts back to old style, so basically anytime u wanna txt with t9 predictive input u always have go in2 options enable then type your txt, if you leave the messege area in the phones menu (which of course u will when u have finished your txt) it will revert to old style input and again u will have to go in2 the menu..........etc........etc :(
