So lets start off by saying that the Z370-A bios is very buggy at the moment, it does not show your applied clock speed in BIOS so you have to boot to windows every time to see if it works. I spent the first hour with the board thinking it was ready for RMA.
So onto the bclk overclocking, sadly it doesn’t work. The best you can get out of it is 102.5 MHz, which gives you a 100 MHz boost to 3.9GHz on all cores and a 4.1 GHz 1 core turbo. You can however lock the all core turbo so it stays at that frequency at all times whilst still having the 1 core turbo active as well. This definitely makes it an impressive chip for the money.
As for the voltage, I’m pretty sure the changes I applied to that sticked.
The chip didn’t get very hot either, doing about 77 degrees celsius on VRAYBench with an Intel stock cooler. It’d still be advisable to put on an aftermarket cooler if you’re going to run heavy multithreaded tasks on it, since that’ll keep it from throttling.
