Been tinkering a tiny bit today with my new Conroe setup (I'm quite the newcomer to this overclocking business
) and was wondering if anyone has any advice / suggestions as to where I can try and tweak my settings here and there. They are set as follows:
CPU = e6300 (w/ Freezer 7 Pro + Sharkoon SE 1000 120mm cable tied to it to replace the stock 92mm fan)
Asus P5B Deluxe (0711 BIOS)
G.Skill PC2-6400 HZ 2GB
CPU: 2.8Ghz (400 * 7)
Vcore: 1.35v
Mem: 5-5-5-5-15 5:4 (DDR2-1000) 2.1v
Everything else it set to Auto with Core Temp reporting the CPU at 43 degrees IDLE. The above settings seem stable for now but crashed earlier when I had my settings at 4-4-4-4-12 and 1.32v on the Vcore.
Thanks in advance for any help
) and was wondering if anyone has any advice / suggestions as to where I can try and tweak my settings here and there. They are set as follows:CPU = e6300 (w/ Freezer 7 Pro + Sharkoon SE 1000 120mm cable tied to it to replace the stock 92mm fan)
Vcore: 1.35v
