Where to plug in 4 case PWM fans?
6 Oct 2004
England
Looking at the Lancool 3 case and a Gigabyte B650 motherboard.
The case comes with 4 PWM fans, there doesn’t seem like there are enough 4pin ports on the motherboard to support this.
How does connecting the case fans to the mobo work in this situation?
Premium cases usually have their own integrated splitter or hub/controller, it's rare that they expect you to connect every fan yourself to the motherboard individually. If you check the manual, or some reviews, it'll tell you the box contents and how they're connected.
Theoretically motherboard fan headers supply enough power to run 3 fans but I really wouldn't want to put it to the test. I believe in playing safe.
Yeah use a hub, they are brilliant.
I have 6 case fans connected into a Corsair hub, the hub then connects to a USB header on the mobo. I can then change the curve and fan speed through the iCue app
Great for cable management too
