Where to plug the cables?
18 Jul 2011
So I have this MoBo:
But I don't know where I should plug these cables:
Power LED + and -
Reset Sw
H.D.D LED
Power Sw
Speaker
Any help is appreciated, thank you,
Billy
in the picture, bottom left.
the first thing to find is what two pins when quickly shorted together turns the pc on.
With the LED's it doesnt matter if you get them the wrong way around, you wont damage it, if theres no light, then pull the plug out and rotate it.
The power and reset switch dont matter either, all they do is temporarily short the two pins they are connected to.
You mean actual sound speakers to listen to the music and game sound effects?
If so it goes into the green hole at the back of the board.
If you are revering to the case speaker that just makes a pathetic beep when you power up? sod it:D bin it:D
Lol. I do know here to plug in speakers you know! I'm not an imbecile.
As stu said, the speaker is pointless.
I remember doing this through trial and error. after 20 mins off fiddling it was all working and then i fell backwards and pulled them all out :mad:
I actually got this right first time! However, I had to pull it all out and reput in the heatsink and fan :@!
How do I make a signature? I want it to say "PTS73 Stingray and proud!"
