Where to put my amp
28 Mar 2005
So i finally got round to buying one.
only a cheapy 300watt one that will give me sound through my carpc untill i get can a better one in a few months. but.....
there is enough room to install it above the PC. but... will that look to much in the middle then??
any other ideas?
Under the seat or in the boot on the side if you want it hidden out the way. Might be advisable security wise with a car pc in there.
Directly above the pc is the logical choice, or if your going to add another amp at some point i would put it vertical on the left or right of the pc.
