I'm just starting to look at water cooling my computer, because the fans are getting on my nerves now. One thing I can't quite figure out though is where to put the radiator on the Eclipse-62.
I was looking at THIS kit as it comes with a mounting bracket to go outside your computer, but I think I would really like to assemble the parts myself.
If I went for a radiator like THIS ONE where can I put it ? Can I still just drill some holes and mount it to the back of my case ? Anyone whose water cooled in this case before (I'm sure there are loads of you) could you give me a bit of a pointer ?
) but I would say only for well experienced builders and still a right pain in the arse.. a 120.3 loop would probably perform better also.
