Where to sell servers?
26 Feb 2009
Exeter
This isnt an advert before any mods interpret it as such :)
After a big upgrade, I've got several (probably 4 or 5) high spec DL380 G4s, which are obviously still worth a fair bit, just no use to us any more.
Is fleabay the best place to shift them? Around here? Down the local market?
Try on the MM and then fleabay if you dont get what you want. Cant hurt. Ebay take a lot of money off you in fees so you can sell it a little cheaper on here as well.
I take it you are just waiting for it to be activated, you just need to enable it in your trust when you have over 250 posts.
Servers seem to go well over what they're worth on ebay. :o
Think its percieved value. There's a lot of places running older kit, especially HP/Compaq stuff and they're too scared to change.
Will get them on the MM first when I get access for a sensible price though
If you get any trade magazines in the office there are normally a bunch of companies specialising in buying 2nd hand IT kit - never used any so can't comment on the prices they pay etc, but have a look anyway.
Isnt it 250 posts and 3 months. Go into your trust and enable it from there.
