Hey all,
Just finished building my new comp and the performance doesnt seem as good as i hoped, I know i made a mistake buying the mobo as it wont overclock my q6600 past 2.7.
The spec is-
Abit fatality FP-9IN9
Q6600 @ 2.7
2x 8800 gtx's in sli- ocuk ones
ocz 6400 ram @ 880 4 4 4 12
ocz psu 700 watt
arctic freezer pro cooler
On 3dmark 05 im only getting 17100 with the cards in sli.
Sli disabled im getting 16210 on one card.
Surely 2x GTX's should get a better performance gain?
Playing Crysis on XP with the very high settings crack @ 1680x1050 res im getting between 21-50 fps with the average around 28. Does this sound about right? when i disable sli and play with one card the difference isnt all that much.
The spec is-
Q6600 @ 2.7
ocz psu 700 watt
