Where's my water going?
Man of Honour
20 Sep 2006
I changed the water in my loop when I changed the res about 6 months ago (EK 150 iirc). I topped it all the way up, did a leak test and all has been fine. Now the res is only half full and no signs of leaks. Eh? Any ideas?
air bubble trapped somewhere I recon...
and how can a sealed system blooming well evaporate for gawd sake.!
You can tell if you've still got air trapped in your loop as the water level will go down when you power up the pump with it open to atmosphere.
Got t be evaporation. On my old watercooling setup with my amd rig which only held about 250ml of coolant in the whole system (pants really) I had to top up every three months.
Over 4 years I went through a full 750ml litre bottle of coolant and not a leak anywhere.
