I am building a pc with mutliple gpus for rendering which will require a beefy PSU and was wondering if anyone can advice on which one to go for.
I was set on the EVGA SuperNova P2 1200W which should serve me fine for 3-4 cards, but saw the G2 1300w model at a much more attractive price point.
Now I do not know which to go for. On one hand the P2 has the platinum rating which should be very efficient and should save some money (over many many years) it also got a perfect score from jonnyguru. On the other hand the G2 is less efficient but with extra head room just in case, it is also £45 cheaper, this would give me the effeciency savings of the P2 upfront.
I am inclined to just go with the G2, but would also pay more for the P2 model if it was the better choice. but what do you think?
My concerns are, reliability, longevity, noise.
Many thanks.
Many thanks.
