Hi,
I am really stuck on which monitor to buy...
I do a bit of gaming but not enough to warrant a 400£+ price tag. I'm looking to spend £350 max but if less for a 1080p monitor is more sensible that would be happy with that ofc! Do I need G sync? I do notice screen tearing when gaming but my current monitor is old, not sure if it is caused by GPU or the monitor? Does the monitor need a G sync module or can I buy a 'G sync Compatible' monitor based on my GPU? I already have a 24i and am looking for another of the same size. I hear IPS can have poor blacks, is it better to stick with a TN panel? Many thanks in advance
System specs
EVGA 980ti hybrid
https://www.evga.com/products/specs/gpu.aspx?pn=16add31d-8463-430a-a2a3-f9f1fd49e9a6
AMD FX8350
https://www.amd.com/en/products/cpu/fx-8350
Acer S240HL
https://www.acer.com/ac/en/PH/content/model/ET.LU50D.013
System specs
EVGA 980ti hybrid
AMD FX8350
Acer S240HL
