which 120mm Fan?
I have one of the Akasa fans with my CPU and it is really quiet and shifts a fair bit of air, they are on offer this week at £10.99.
I have not personally used or seen one in operation but have seen people who swear by the Scythe Gentle Typhoon which is also on sale at £11.99
To compare the:
Akasa - 6.9-28.9db (noise) 83.6 cfm (airflow)
Scythe - 21db (noise) 58 cfm (airflow)
Obviously noise is best in lower figures and airflow is best in higher figures. So you will have to decide which you would rather have.
I use the akasa fans for my cpu aswell and although they are a little noisy at full speed, they definitely shift awesome amounts of air.
Scythe Gentle typhoon as mentioned has good "static pressure" which means it can force the air through the rad fins.
A quick Google showed me this. Going by that alone I would think you should see a couple of degrees difference.
Although that is for air cooling, a water radiator might be different.
