Which 120mm fans.
5 Nov 2007
Glasgow
Which one should I buy:
1. Xilence XPF120R Red Wing
2. Yate loons 120mm
Any other fans under £10 that are better than above 2. Thanks
I quite like the ACRyan Blackbird4 Fans. 2000RPM and a massive 77CFM
so really any fan will do you...
i would recommend
Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan £6.89 each form OcUK (first choice)
Xilence XPF120R Red Wing 120mm Quiet Fan £6.89 each from OcUK (second choice) and the colour looks good
