- 14 Jul 2005
- Birmingham
Hi all,
I want to get 2x 140mm fans as intakes for the front of my case.
I do not know whether to get fixed speed, slow rpm fans that runs off the molex power at a fixed speed all the time, and will be very quiet. eg: https://www.overclockers.co.uk/scythe-slip-stream-140-xt-500rpm-fan-140mm-fg-059-sy.html
OR
Whether to get variable speed fans that will run off the motherboard system headers and allow for speed increases if required. I am looking for a good airflow and quiet. eg https://www.overclockers.co.uk/alpenfoehn-140mm-wing-boost-2-plus-pwm-fan-white-fg-023-al.html
I see some fans come with 7V adapters. I assume these are so that the fan can be run slower and quieter off the molex power?
I currently have 1x120mm intake fan and 1x120mm exhaust fan. I don't have a GPU yet, and I think I will need more airflow when I get one due to the temperatures they give out.
Also, do I need to ensure the intake fans are blowing over the HDD? My case has room for 3x120mm or 2x140mm & 1x120mm intakes at the front, and it also has a removable panel above the HDD bays. If I remove this panel I can fit a fan so that it intakes over the HDD directly. If I don't remove the panel, then I cannot get an intake fan in that spot.
The noisiest fan in my system is the CPU fan. It came with the cooler I bought - an alpenfohn matterhorn pure, and the fan is badged as an alpenfohn fan. However when it spins up beyond 1000 rpm it is quite loud. Can I get quieter CPU fans?
OR
