Which $150 XL case?
17 Jun 2013
Excuse the dollah sign, I don't have her majesty's sterling for some odd reason...moving on...
I dont know if to get the Shinobi Benfinix XL, OR the Corsair Obsidian 650d
or, for the pure crack, the Corsair 540 cube thing.... I dont know if i love it or hate it, but ive never built by own PC this is my first build of a real PC, its a z87 i5 gtx680 build, what case would do it justice?
thanks
http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-CS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-076-BX&groupid=2362&catid=1850
http://www.overclockers.co.uk/showproduct.php?prodid=CA-240-CM&groupid=2362&catid=2231
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-AN&groupid=2362&catid=160
http://www.overclockers.co.uk/showproduct.php?prodid=CA-075-SV&groupid=2362&catid=1092
http://www.overclockers.co.uk/showproduct.php?prodid=CA-062-SV&groupid=2362&catid=1092
likley candidates i think
also, where is the dam dimentions for the Silverstone shells?? ami going mad, i cant see them
here...http://www.overclockers.co.uk/showproduct.php?prodid=CA-062-SV&groupid=2362&catid=1092
I'd say the 650D too..
There is a lot of good cases around that mark but the 650D is superb..
I would say the Raven 2, but it's Out of stock (thats a great case too).
Are you planning on bolting the 2 500R's together to make a SUPERCASE!!! :D
Thanks guys, nice cases.... I need to order within 2 hrs for del tomorrow, im so excited im about to wet myself! but........I just cant decide, and do i REALLY need such a big case, I thought so, but the max ill use is 2 in sli or xf
I want a quality new case worthy of a z87 oc haswell build.. still dont know what cooler either, or card...
god i like the 650, i worry its too old now, i dunno, the nzxt seems to shiny for me
and also what about this, its 30 quid off, but ai dont know... gosh
get the 600 it will handle everything now, unless your going super water cooling
as for coolers depending on your budget but coolermaster hyper eve 212 is a brillant cheaper cooler but o/c is out of stock atmo.
here a few others pricey side , most of the coolers come in a few colours if you have a theme
well spotted doom!! i like that case ¬¬
YOUR BASKET
1 x Noctua NH-D14 Dual Radiator CPU Cooler £65.99
1 x Thermalright Silver Arrow SB E Extreme CPU Cooler TY-143 Fans £53.99
1 x Prolimatech Black Megahalems CPU Cooler £49.98
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £44.99
Total : £228.44 (includes shipping : £11.25).
i got one its ok
but theres not much difference between that and my megahalems
like 2-3c i will say they are loudish even on lowest setting unless you buy other fans but then its more ££
as for gpus just look in gpu section some good advice in there , the one in my sig is a good card but depends on your budget , what you want it for etc etc
i got one its ok
i like the orange one! i have giga z87 oc orange board, but the big black thing goes well with the 650
