Which 20" monitor?
26 Mar 2008
Leicester & Northants, UK
I'm currently using an LG M208WA, but am disappointed with it (text doesn't appear extremely sharp - bit hard to read from), so I'll probably be sending it back if they'll accept it. So I'm going to be on the lookout for new one, but there are so many choices I dont know what to go for. I'm trying to stay away from high contrast ratios, the LG has a dynamic 3000:1, but tbh it's put me off that because its not that great.
I need a DVI input and preferably a VGA or component, so I can plug my 360 into it as well. I was looking at the Dell E207WFP but it doesnt always get favourable reviews - according to a few I read the colours arent amazing and subtle colour changes arent visible so images tend to look flat. Would rather stay away from multi-function ones as I'm thinking that may be why my LG isnt amazing. Jack of all trades, master of none and all that :rolleyes:
My budget is around £200. Hopefully thats enough info for you to recommend me something good :)
Hmm I think 24" is too big for me, I dont like huge screens. 20 seems about right to me, I think anything bigger would be too much. I dont have enough space really, either. I'd have to have it sitting to one side as I have a shelf in the way and my 20" lg only just fits. Can't be good for posture or anything.
smilertoo, what model of dell is that?
I'm also looking at Iiyama and Viewsonic, in particular the Viewsonic VX2025WM. Any good?
I'll check out some reviews etc to see what the quality and specs are like. What inputs does it have?
