Which 22" Monitor?
6 Apr 2007
Manchester
Hi,
I'm about to buy a 22" from OcUK but not sure which one to get, i like the look of the 22" Dell and the Samsung but i have heard bad things about the samasung!
Any ideas would be great btw it's got to be black :)
Bad things about the samsung:
226BW - It can be shipped with one of 3 different panels built in:
S) Made by samsung, the best quality one
A) Made by AU Optronics, almost the same as S quality panel but requires calibration to make it perfect
C) Made by Chi Mei, worst quality
Unfortunately, most 226BW are now C panels
You should hold out for the 226CW if you want the best quality, they use S panels because of the way the CW backlight has proprietary manufacturing methods which only samsung have perfected
But to be honest, the samsung is still better than the dell due to better contrast ratio and response time. Also dell have't released a non TN 22inch panel... so the difference between them suggests you should go for the samsung, even if they do ship C panels. Or wait for the CW if you're a perfectionist.
iam using the LG model its good for me and the same specs as samsung 22.
The only problem i had was the stand was very tight u have too lay the lcd on the front and too put on the stand rock it from side too side and too move the stand when its new move the stand while on the front up and down a few times but other than that its very good no dead pixs etc very good specs for under 170 pounds not allowed too say where i got mine from tho. :D
That impressed by this LCD just grtting my self another one side by side. :cool:
dan1987 said:
I have the 22" Dell and am very impressed with it, great picture and colours and no ghosting in games.
every tft in the world has ghostng
I got a Hanns-g HW223DP a couple weeks ago and I am very pleased with it.
I am no gamer so I can not comment on it from that angle.
