Which 22" monitor?
19 Oct 2008
I'm looking to buy a new 22" monitor. I have a Samsung at the moment so i was considering sticking with them or possibly LG just out of sheer reputation and word of mouth. But if there is a quality monitor available by someone different im prepared to consider it.
My only limitations are that i want a DVI port, and that its height including the stand is no more than 41cm or else it wont fit under my shelf. I dont really play any games, just watch a lot of tv shows and films.
So if anyone can give me any highly recommended examples, or point me towards any reviews it would be much appreciated as im struggling to make any kind of decision at the moment!
Cheers
most 22" are tn panel and if u dont play any games then avoid them like the plague.
viewing angles are usually quite poor on tn panels but they have a super fast response time which is ideal for gamers.
try 20" or 24".........24" would be better for movies.
