Which 24" monitor for Gaming on a 8700k, 1080ti - up to £150 budget ?
You should be able to hit 144fps on 1080p with that setup.
So if you can get a 144Hz monitor within your budget, I'd go for that.
Never understood why people buy crappy cheap monitors or audio equipment.
Spend all that money on a 1080 and 8700 and then buy a 150 quid monitor.. really?
This. Buy £900 worth of CPU/GPU then make the most of it with a poor quality panel?
Makes little sense!
Not quite sure why you'd have such a good pc then buy a rubbish monitor?
It's the thing you look at all the time you are using your expensive pc. It should be comparable to the rest of the system.
Budget limitations. It will be fine for now with the Acer XB240Hbmjdpr Gaming 1ms 144Hz (non G-Sync) for £179.
The rest,
Fractal Design Meshify C Midi Tower Case - Black Tempered Glass Window
Intel Core i7-8700K 3.7GHz (Coffee Lake) Socket LGA1151 Processor - Retail
Gigabyte Z370 AORUS ULTRA GAMING INTEL Z370 (SOCKET 1151) DDR4 ATX MOTHERBOARD + £20 Steam Voucher
be quiet Dark Rock 3 Performance Intel/AMD CPU Air Cooler
Corsair 16GB KIT DDR4 3000MHz CL15 Vengeance LPX black
EVGA 650 GQ Modular Gold Rated 80+ Power Supply
1TB Seagate Guardian BarraCuda HDD 2.5" 7mm SATA III 6Gb/s 128MB Cache
Samsung 850 EVO 250GB 2.5inch SSD + Assassins Creed
Gigabyte AORUS NVIDIA GeForce GTX 1080 Ti 11G 11 GB GDDR5x 352 Bit Memory PCI Express 3 Graphics Card + Destiny 2
£1705 including delivery
Monitors are pretty subjective to me, depends on your usage type. If you play a lot of fps then you naturally would want a high refresh rate monitor surely? I follow some of the pro pubg players streams and interestingly they are all using 144hz 24" 1080p TN panels without any frame sync, no fancy IPS gsync in sight... There's probably a reason for that and it won't be budget.
Lol, that's pretty crappy of them really, I've seen it running on my friends £700 gsync with his 1080ti monster rig... Couldn't actually tell it was doing anything other than running high fps without screen tearing. Expensive gimmick.
