- 4 Mar 2007
Mine has just died so i'm in the market for a new one, max price £450
Thanks
Thanks
http://www.overclockers.co.uk/showproduct.php?prodid=MO-054-SA
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Interface: Analog / Digital
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 3000:1
- Viewing Angle (H/V): 160°/ 160°
- Brightness: 400cd/m2
- Height Adjustable stand with tilt & swivel
- 3 Years On-Site Warranty with Samsung
£269.99
£317.24 inc VAT
Taht dell review is very old when it jsut come out and therefore is not comparing it to todays standards where it may not be as good as it is now. 6ms is quite a slow refresh rate for competitive fps gaming. But i gues 5ms isn't much better.
just ordered myself a 2407fpw, hopefully it will be the new revisionIm also after a 24" Monitor, itll be for use within a studio and i cannot justify apple prices for there cinema displays,
so what screen would be best for in a studio, something with really good quality imagery!
i have about 450-500!
-Neoni.
)not really any better in fact. The 5ms quoted figures for models like the Samsung 245B are an old style ISO response time for only the black > white transition. The G2G quoted figures nowadays show a more realistic idea of overall responsiveness, where RTC has been used to boost response times.
more details here anyway: http://www.tftcentral.co.uk/specs.htm
panel tech comes into play, but it could be argued that the 6ms G2G S-PVA panels are slightly superior in practice in terms of response time, as compared with the 5ms TN Film generation
ps, for original poster, the SM245B and 2407WFP-HC are both reviewed here: http://www.tftcentral.co.uk/reviews.htm![]()
Are you sure?
I thought all TFT's had a Black to white response time of 16ms and when manufacturers couldn't get it any lower they then advertised performance using the G2G figures 12ms - 2ms.
ISO response times have pretty much hit a limit, but it varies from one technology to another. In truth, it might not be as low as 5ms for TN Film panels (third party tests suggest it isn't quite that fast), but manuf claim to have recorded a transition black > white this fast now. Modern screens have the following limits if manuf readings are to be 100% accurate:TN Film = 5ms ISO, then where RTC is used, they reach 2ms G2G
S-PVA / PVA = 12ms ISO, or 6ms G2G if RTC is used
MVA / P-MVA = 16ms ISO, or 8ms G2G where RTC is used
IPS / S-IPS = 16ms ISO, 6ms G2G where RTC is used
You may notice a slight change if you moved to a non RTC TN Film model (5ms TN Film like the SM245B for example), but i will say that they are more than adequate for most average users and unless you're a really serious gamer, it should be fine. The RTC enabled VA / IPS generation are quite comparable as well, perhaps a little more responsive in practice than the 5ms TN models, since RTC is used to improve responsiveness across G2G transitions.more than adequate for most average users and unless you're a really serious gamer, it should be fine.
Assume that's the VX922. That is one of the most responsive models in the market, so a lot to live up toYou may notice a slight change if you moved to a non RTC TN Film model (5ms TN Film like the SM245B for example), but i will say that they are more than adequate for most average users and unless you're a really serious gamer, it should be fine. The RTC enabled VA / IPS generation are quite comparable as well, perhaps a little more responsive in practice than the 5ms TN models, since RTC is used to improve responsiveness across G2G transitions.
