Dell Ultrasharp 2407WFP-HC 24" Widescreen 375.99 (HD
The Dell™ UltraSharp™ 2407WFP-HC 24-inch widescreen LCD flat panel monitor redefines the performance of LCD displays with a stylish Dell design and advanced functionality. Featuring - TrueColor technology, the UltraSharp™ 2407WFP-HC monitor offers up to 92% high-colour gamut and 1920 x 1200 pixels resolution, providing deep, crisp and bright images. This high-performance monitor includes enhanced features with its 4 x USB 2.0 ports, analogue, s-video, component, - composite and digital (DVI-D) connectivity with HDCP (High-Bandwidth Digital Copy Protection) - - support and is designed to deliver exquisite, jitter-free images and colour uniformity. Its PIP (picture-in-picture) and PBP (picture-by-picture) features are ideal for video editing and 3D imaging, as both source and destination video can be viewed in a single window. The UltraSharp™ 2407WFP-HC monitor is compatible with the Dell™ AS501 Soundbar (sold separately) providing multimedia capabilities to the flat panel display. Dell ™ branded monitors undergo exhaustive testing for performance, reliability, durability and compatibility with Dell™systems
- 1920 x 1200 (WUXGA+) Optimum Resolution
- Supports advanced features like PIP (Picture-in-Picture) and PBP (Picture-By-Picture)
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 6ms Response Time
- 400 cd/m2 Brightness
- One DVI-D Input w/HDCP Support
- One Analogue Input
- One S-Video Input
- One Composite Input
- One Component Input
- Height adjustable stand (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader
When you buy a DELL monitor from OcUK you get guaranteed next working day delivery and a 4yr on-site next business day warranty service provided by DELL over their STD 3yr service. Save money by buying from OcUK and at the same time get quicker delivery and better warranty.
BenQ FP241W 24" Widescreen HDMI/HDCP LCD HD Monitor 422.99 (HD
The world's first LCD monitor with an HDMI interface and support for 1080p HD video, the BenQ FP241W provides the very best experience of video, photographs, television programs and movies. Satisfying all your AV entertainment needs. What's more, the FP241W's 24" wide-screen design lets you view two independent A4-size windows simultaneously. And with its PIP (picture-in-picture) feature, you can play back video from two different sources, giving you the productivity benefits of dual monitors in a single display. Exclusive Advanced Monitor Accelerator (AMA) and Senseye! technology, together with a high 800:1 contrast ratio, not only allow crisper display of still images, but also enable exquisity smooth video playback. In addition, you can swivel, pivot, and tilt the screen, as well as adjust its height, for the most comfortable viewing. And handy integrated USB ports make it easy to attach a webcam for videoconferencing, as well as other USB peripherals such as a digital camera. Whether working or playing, the BenQ FP241W makes things easy for you. The FP241W can not only enrich your your personal entertainment options, but it is also ideal for work environments as well, with features that can enhance your productivity, whether your job involves complex spreadsheets, intricate graphics or high powered stock trading.
- Now supports 1:1 Pixel Mapping
- Full HD Support (1080p)
- HDMI Interface
- PIP (Picture-in-Picture)
- senseye technology!
- Full pivot, swivel and height adjustment
- Built in USB Hub (3 Ports)
- 1920 x 1200 (WUXGA) Optimum Resolution
- 6ms Response Time
- 500 cd/m2 Brightness
- Viewing angle: 178/178
- One DVI-D Input
- One S-Video Input
- One Composite component Input
- One HDMI Input
- Warranty : 3 year on-site warranty supplied by Manufacturer
Iiyama B2403WS-B 24" Widescreen TFT LCD 3ms 299.99 (HD
The new iiyama flagship 24" display is ideal for the Home Enthusiast, Gamer and Business professional. The 1920 x 1200 pixel panel has the latest advancements in technology, boasting a 2000:1 Dynamic Contrast Ratio, which can be disabled for greater color accuracy and a 3msec response time ensuring the best possible video and animation playback with minimal blurring. Of course, the B2403 is HD Ready and incorporates the HDMI input for connectivity between DVD Players, Games Consoles and Graphics Cards choosing this interface type. A HDMI to DVI cable is now included as standard.Iiyama Pro Lite B2403WS-B1 - Flat panel display - TFT - 24"
- Flat panel display / TFT active matrix
- Stereo speakers
- (WxDxH) 56.6 cm x 22 cm x 44.5 cm
- Weight 8.7 kg
- Diagonal Size 24" - widescreen
- Dot Pitch / Pixel Pitch 0.27 mm
- Max Resolution 1920 x 1200
- Display Positions Adjustments Height, pivot (rotation), swivel, tilt
- 24-bit (16.7 million colours)
- 16:10
- Response Time 3 ms
- Image Brightness 300 cd/m2
- Image Contrast Ratio 2000:1 (dynamic)
- High-Definition Multimedia Interface (HDMI)
- Audio Output Speaker(s) - stereo - integrated
- Signal Input HDMI, VGA
The Iiyama seems expectional especially at that price, anyone got one?
Any i should add.. for serious gaming and image quality.
)The Dell™ UltraSharp™ 2407WFP-HC 24-inch widescreen LCD flat panel monitor redefines the performance of LCD displays with a stylish Dell design and advanced functionality. Featuring - TrueColor technology, the UltraSharp™ 2407WFP-HC monitor offers up to 92% high-colour gamut and 1920 x 1200 pixels resolution, providing deep, crisp and bright images. This high-performance monitor includes enhanced features with its 4 x USB 2.0 ports, analogue, s-video, component, - composite and digital (DVI-D) connectivity with HDCP (High-Bandwidth Digital Copy Protection) - - support and is designed to deliver exquisite, jitter-free images and colour uniformity. Its PIP (picture-in-picture) and PBP (picture-by-picture) features are ideal for video editing and 3D imaging, as both source and destination video can be viewed in a single window. The UltraSharp™ 2407WFP-HC monitor is compatible with the Dell™ AS501 Soundbar (sold separately) providing multimedia capabilities to the flat panel display. Dell ™ branded monitors undergo exhaustive testing for performance, reliability, durability and compatibility with Dell™systems
- 6ms Response Time
- One S-Video Input
)The world's first LCD monitor with an HDMI interface and support for 1080p HD video, the BenQ FP241W provides the very best experience of video, photographs, television programs and movies. Satisfying all your AV entertainment needs. What's more, the FP241W's 24" wide-screen design lets you view two independent A4-size windows simultaneously. And with its PIP (picture-in-picture) feature, you can play back video from two different sources, giving you the productivity benefits of dual monitors in a single display. Exclusive Advanced Monitor Accelerator (AMA) and Senseye! technology, together with a high 800:1 contrast ratio, not only allow crisper display of still images, but also enable exquisity smooth video playback. In addition, you can swivel, pivot, and tilt the screen, as well as adjust its height, for the most comfortable viewing. And handy integrated USB ports make it easy to attach a webcam for videoconferencing, as well as other USB peripherals such as a digital camera. Whether working or playing, the BenQ FP241W makes things easy for you. The FP241W can not only enrich your your personal entertainment options, but it is also ideal for work environments as well, with features that can enhance your productivity, whether your job involves complex spreadsheets, intricate graphics or high powered stock trading.
- HDMI Interface
- 6ms Response Time
- One DVI-D Input
- One S-Video Input
- One HDMI Input
)The new iiyama flagship 24" display is ideal for the Home Enthusiast, Gamer and Business professional. The 1920 x 1200 pixel panel has the latest advancements in technology, boasting a 2000:1 Dynamic Contrast Ratio, which can be disabled for greater color accuracy and a 3msec response time ensuring the best possible video and animation playback with minimal blurring. Of course, the B2403 is HD Ready and incorporates the HDMI input for connectivity between DVD Players, Games Consoles and Graphics Cards choosing this interface type. A HDMI to DVI cable is now included as standard.Iiyama Pro Lite B2403WS-B1 - Flat panel display - TFT - 24"
- Stereo speakers
- Weight 8.7 kg
- 16:10
