Which 240mm AIO for <£75
12 May 2011
Southampton
There are lots to choose from and I value quietness the most. I don't need RGB (but don't mind if it has it) and it needs to support 115X sockets as well as the modern ones.
Any recommendations?
If low noise is top priority then I would always recommend the be quiet! Silent Loop 2 range but it's a fair bit above your budget.
If you buy an AIO where the fans are PWM and have standard 4pin connectors to the motherboard (rather than proprietary connectors that go to the pump unit) then you can always replace the fans for quieter units later on.
