Which 27" 1440p OLED - ASUS PG27AQDM vs LG 27GR95QE-B
10 Jan 2024
The Nostromo
Afternoon Guys and Gals, time for some 'War & Peace', so here goes..... I've took the step and moved back into PC gaming after a long hiatus, gaming wise I'd likely be playing a mix of FPS, survival and narrative story driven games (maybe to odd RTS) so would want a good all-rounder experience.
So right now I'm looking at adding an OLED to my new setup (this was priced into my budget) and I've narrowed it down to the 2-off 27" monitors in the title (ASUS PG27AQDM and LG 27GR95QE-B), I can purchase both at around the same price of £800, so I'm little split on what to go for, I see people raving about the ASUS for its SDR/HDR brightness and accuracy (although not sure if that would be an issue with burn-in as its not included in their warranty?), but I also note it's missing some features such as HDMI 2.1, USB-C input and proper hardware / factory calibration, all things the LG has.
Just to note, I was also looking at the ASUS PG34WCDM 4K Curved Ultrawide OLED which is due out Mid-February, but I'm a little hesitant to push beyond my budget, this would virtually be >£1300 to buy, I've never used an ultrawide monitor and I'm not really sure I want to move into 4K gaming at this screen size (I already use a LG CX 4k OLED for PS5/XSX console gaming).
So folks, which would be your pick and why? Help me OCUK Forum, you're my only hope!
My setup for info:
  • CPU: 7800X3D (AIO Cooled)
  • RAM: Lexar Ares DDR4 - 6400mhz CL32
  • GPU: 7900XTX
  • MOBO: ASUS B560E-E Gaming WIFI
I’ve had both - returned the LG (brightness, lack of uniform brightness in desktop) and kept the ASUs. The ASUS is faultless.
And I can actually get the ASUS fractionally cheaper, only by about £20, but hey that a bit of steam credit haha, so I'll put that down as a mark for the ASUS, nice to get some real world feedback, appreciate it.
With HDMI 2.0, bandwidth wise, can you sill get the full 1440p / 240hz experience or would that be limited to the Display ports?
Did you consider the Alienware AW2725QF?
I had seen they had a new range coming, do we have an estimate on EU/UK release? I think they've already dropped in the US yes? I could potentially be interested in the 1440p 360hz model, although this sounds a bit strange, taken from that linked article:
Although the Dell spec sheet says (confusingly for the consumer) that the “HDM I 2.1” port only supports the older TMDS bandwidth from HDMI 2.0 and can only support up to 2560 x 1440 @ 144Hz – so not really offering any of the new HDMI 2.1 bandwidth, resolutions or refresh rates at all.
I only ever use DP so wasn’t a consideration for me.
Thanks again, think I'm settled on the ASUS and will just run it through DP, with owning the monitor is there any other advice or recomendations you have after I hook it up?
Update to latest firmware straight away it fixed a lot of could problems. There’s some standard settings on Reddit which are very good. The one for “racing mode” gives a very clean and perfectly balanced image and that’s what I use 24/7.
