Which 280x (or 290) for mining
2 Oct 2011
Wodensbyri
Hi guys :)
Currently have the build in my sig and fancy having a go at this mining lark!
From doing some reading I think I'm looking for a voltage unlocked 280x, due to them being the best bang for buck - and voltage unlocked so i can undervolt.
There is a 290 which is voltage unlocked too and not much more expensive than the 280x's;
YOUR BASKET
1 x Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card £329.99
1 x Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card £299.99
1 x MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game £299.99
1 x Asus Radeon R9 280X DirectCUII TOP 3072MB GDDR5 PCI-Express Graphics Card £299.99
Total : £1,239.55 (includes shipping : £8.00).
Which would be the best route...?
Thanks!
The cheapest non-reference cooler one? :P
This, if you are keeping it at home then go for the cheapest non-reference cooler as they are loud and if you are mining, then the fan will be at least 75%.
There aren't any non reference 290's at the moment, but there are 280's if you want them.
Example of fan noise
:eek:
Wouldn't go for the Asus 290 as its got stock cooling, MSI with the free game is my pick.
:eek:
Good call guys, I had read that the fan noise was loud but didn't realise it was so bad :eek:
No reference 290 for me!
The poor powercolor support puts me off :(
http://forums.overclockers.co.uk/showthread.php?t=18231329
The MSI will need a BIOS flash to adjust voltage.
Would a BIOS flash invalidate warranty - I have a feeling I know the answer to that question.....
