Which 2Gb memory for Shuttle SK22G2?
19 Oct 2002
Maidenhead
If anyone here has one of these i could really do with some advice as i cannot afford to buy the wrong memory. I assumed that i could just put my old ddr in, but i didn't consider that the socket/connector might be different.
It supports: DDR2-533/667/800. I was looking at the GeIL advertised above, but really need compatibility rather than performance, although performance would be nice ;)
For as long as i can remember i have been buying Corsair and they have never failed or caused me any problems. I would like, if possible to continue using Corsair, only problem being im on a bit of a tight budget - i wasn't expecting to have to buy memory :(
Cheers
This poster is using Corsair Value Select PC5300. Crucial list compatible modules too.
Don't know what's the maximum memory voltage the SK22G2 can provide, but it very likely you'll be limited to slower latencies.
Ran out of money and bought some cheap *ahem* Kingston LOL, i found the Shuttle compatibility list and it was there, thought sod it! This isn't meant to be some beast of computer ;)
